I failed finding for the "polygon" algorithm to mesh a 5 sides surface
In addition, I wanted to add fixing points by path using existing nodes, but I've found nothing in all options nor specific icons: what am I missing?
Note:
- I was used, with solid map, to clik on the "surface+elements" source, and "surface+elements" target, plus guide surfaces with "align"
- I tried to reproduce here the same methodology, but I'm wondering if either HM used the (source) surface, (source) elements or both?
- however i need to try several time before to success … 🤪
- (the message immediatly dissapears on the bottom left of the toolbar, so difficult to see what happened)
Thanks for your time
Paul
