Can you define a Rivet connection between 2 parts that are not in contact ?
Hi Tzachi,
No, you cannot define a rivet connection between two parts that are not in contact in SimSolid. Rivet connections (like welds or bolts) require physical contact or overlapping faces so the software can transfer loads correctly between the connected parts. If the parts are not touching, you would first need to adjust the geometry so that the surfaces or edges intended for the rivet are in contact. Once contact exists, you can define the rivet connector to properly simulate load transfer.
Sourav
Join us for a community conversation on Pulse Width Modulation (PWM), a fundamental technique in electric motor control, and explore how different PWM strategies can yield significantly different results. This webinar provides a comparative analysis of various PWM methods and their effects on motor efficiency, torque…
Join us for a community conversation to discover the Advanced Iterative Solver(AIS) in Simcenter Feko and its application to electrically large and computationally demanding electromagnetic models. The session will provide a general overview of how iterative solution methods can help improve efficiency of large scale…
