I've encountered a problem. I have four assemblies, differing only in the thickness of one part; everything else is the same. I'm considering only meshing the part with the difference, importing the meshes from the first mesh and merging them with the meshes of the other parts, without re-meshing. Is this method feasible? Also, how should I configure the import/merge settings? I just tried it, and the import/merge function isn't working. How can I resolve this? Thank you!
