Hello everybody
When extracting data for the energy loss variables (total, normal, tangential), if the value is negative is it because it has a dissipative behavior? Or what is the correct way to interpret energy loss?
Thank you.
Hi, I believe this would be energy gained, e.g. from source like moving geometry.
Hello
Okay, I understand. Therefore, all EDEM values that are positive is the "effective" energy loss due to collisions, friction and so on?
