In FEKO, I have created a wire helix with diameter of 4 inches and 5 turns (1 inch per turn). I want to plot the S-parameters for this simple inductor, but everytime I plot them, S1,1 is 0 dB or slightly positive at 1 dB. I have added straight lines to each end of the helix coil and made these lines each a port. This is all I should need to do, but the S-Parameter plot shows nothing is getting through the coil with S1,1 at 0.
Ive tried adding a box of free space around the coil, but same results. I have unioned the coil and two straight lines but still get the same results. Both ports active when setting up the s parameters.
Please assist.
