I am currently using the morph function to write a script, but I’ve found that when using “by box” or “by cylinder,” I’m unable to select the handles based on their positions.
If I want to select handles or domains by location, what are the common or recommended methods to do so?
"by box" x0 y0 z0 x1 y1 z1 syst location contained all tol
Place entities on mark_id, if they are inside/outside/on the boundary of the box.
This is currently supported for nodes, elements, connectors, components (FE and connectors only), loads, equations, loadcols, systems, systcols, vectors, vectorcols, blocks, groups, sets, contactsurfs, points, lines, surfaces, solids and parts (FE and geom).
