I moved from the old 2022.3 version to more recent version 2025 and 2025.1 (both have the same problem).
With the newer software whenever I try to use old models or create new ones that use contact between 2 cad models (both step and parasolid) the simulation get stuck in "export geometry" and stops responding. There are no warnings it just stops.
I'm using contact with impact model and friction disabled. I tried step 203 and 214, parasolid and prt (I have siemens nx), also going trough Inspire does not fix the problem.
is it possible that there is a geometry tool not working properly? Is there a solution?
The only way to make contact work is using basic geometries like cylinders created inside motionview.
Thanks in advance
