I am trying to simulate a thin plate whose thickness has to go smaller and smaller. I have a problem because FEKO keeps meshing the edge of my structure with thin triangles :
I understand that since there is a lateral face of small thickness, FEKO tries to keep the ratio of my triangles reasonable. However, I really don't need precision at the edge of my structure.
- Would someone has a solution to get a thin plate without having to mesh a lot the edges ?
→ Right now my structure is a rectangle, which I sweep by my thickness value. I tried defining it rather by simply a rectangle and then associate to it the copper with the thickness equal to my plate thickness. However, it really does not gives the same results so I guess this is not a good way to proceed ?
- Also, is it that important to keep edge triangle size ratio small ?
Thanks a lot,
Pierre
