Follow the tutorial to learn Co-Simulation with MotionSolve. The software versions are all v2025. There are no errors when running in MotionView, but errors occur when running in Twin Activate. After several attempts, the problem still cannot be solved. Could you please help me? Thank you. The tutorial address is: https://2025.help.altair.com/2025/twinactivate/help/en_us/topics/math_solutions/tut_cosim_mbs_t.htm#task_epd_mcm_lw
Hi!
If you use the finished version of this tutorial model, does the error still persist?
Hope this helps!
Adam Reid
This error is not clear whether it is a problem with the software settings or not. However, even when using the final version of the tutorial model, the error still occurs.
I tried it again and it worked successfully.
