Hello everyone.
I´ve created a mesh from an imported model, as usual, without any change to my workflow (check geometry, define patches, define surface mesh parameters, volume mesh) and the software manages to create a mesh.
The problem arises when I try to export solver deck as CGNS or openFoam files, where in the first case the file has a size (couple Gb) but can´t be opened by ParaView or in the second case creates the folders (0, constant and system) but they are all empty.
This has never happened before, as this is a geometry file that I´ve worked in before and this error is very strange. Anyone can help me troubleshoot this?
