I have a problem using .tir files when trying to setup my HyperStudy. Let me walk you through my approach.
First I define my MotionView Model with the Solver Input File being a .xml. then I create three Parameterized Files, one for each Tire pair that is being used in my MV Model. The Resource is the .tpl file and the Solver Input is the .tir file being saved in approaches/setup_1-def/run__0001/m_2/[…].tir (for the other two m_3 & m_4).
When creating them, I have to create parameters from the .tpl files. I highlight vertical_stiffness and vertical_damping. Then I import the variables. And they seem to bee correctly defined. Test Models works fine too. After creating my Output responses I setup an optimization.
When solving the Evaluations no .tir file is being saved in the approaches/opt_2/run_00001/m_2 folder. But the Input Variable is changed in my Evaluation Data with no change in my output.
My Quenstion is: How do I setup my MotionView or HyperStudy file, so a .tir file with new parameters is created for each evaluation in my optimization? And how do I link the newly created .tir files to my MotionView file?
I would appreciate your insight and ideas.
Here are screenshots of my HyperStudy file.
