Hello. I am trying to perform a simple high pressure die casting simulation.
I followed every step but at the end, when the results are compiled, it always shows me that: "There are no results to display."
When I follow simple tutorials, I can do every step until the running step, where I have to run it on Batch mode because when I try to run it as usual, it doesn't work.
This is the tutorial I am following to:
Tutorial: High Pressure Die Casting
Does anyone had the same problem? Does anyone know the source of this? Where can I see my results?
Thank you in advance
