I am new to Embed and Launchpads, but I was able to setup a simple CAN transmit on a LAUNCHXL-28069M, but am having problems with a LAUNCHXL-28379D. It seems like there are less options in the CAN Config dialog. I have selected CANB as that's what appears to be routed to the transceiver on the Launchpad. I am using Embed 2017.2 and CCS 7.1.0.
Any ideas on what I could be doing wrong?
You can look at a working example at C:\Altair\Embed2025_64\cg\examples\Delfino\CAN\canTxF28377S.vsm
The key is to get the CAN bus rate to match the device you are connected to. We normally use 1MHz in our examples.
