I was running several transient magnetic 2D cases, varying the d-axis current level in a permanent magnet motor. There were about 155 (31 x 5) cases to perform, which I automated using PyFlu. After running about 120 cases, the program simply crashed, without any message, after a saveProjectAs(case_name) command. I'm attaching the hs_err_pid24596.log file. I'm using an Intel(R) Core(TM) Ultra 9 285H, 16 cores, 64G, Windows 11, 64 bit machine.
I tried to send a report to github.com/corretto/corretto-21/issues/ but not sure if it was uploaded.
