Does the 2026 version support the ability for EDEM to perform DOE analysis in HyperStudy? Has this feature been updated? Specifically, I'm referring to the capability of simultaneously calculating five DOE parameter values, with each calculation utilizing a different GPU, and then, after completing these five calculations, using the same five GPUs to continue calculating the subsequent five parameter values. I'm just giving an example, but is there a similar functionality
