Hello, i want to simulate a wing with extended split flap on the bottom surface of the wing. I need help in finding the best strategy to set up the simulation in FlightStream. I am not sure what to declare as a base flow region. Its obvious that the blunt trailing edge of the wing and the flap are both base regions but i am unsure on how to treat the backside of the extended split flap. The flap is depolyed downwards up to 60 degrees of deflection. If there is any experience in modeling such a problem correctly to get accurate force data, I would appreciate some guidance.
