I use EDEM 2026. I found that when using my custom API model together with EDEM’s built-in Temperature Update Model, the particle temperature does not change during the simulation. In other words, the heat flux calculated by the Heat Convection Model does not appear to be passed into the Temperature Update Model for temperature updating.
Could you please help me resolve this issue?
Is it possible to use two particle body force models?
Can the heat flux calculated by the Heat Convection Model be transferred to the Temperature Update Model, or is there an issue with my code?
Thank you very much.
