Hi all,
I’ve been trying to analyze the particle collision number in EDEM 2025.1, but I’m encountering an issue where the collision number results remain zero.
So far, I have tried the following approaches:
- Enabling the Collisional Energy Tracking physics model
- Running the simulation using the CPU solver only
- Enabling Collisions (Particle–Particle) in the Data Save Configuration options
However, the collision number values are still reported as 0.
Could you please advise whether there might be any additional settings I should check, or if it is possible that the collision number is indeed zero under certain conditions?
Thank you very much for your help.
Best regards,
Selena
