I am looking into using ERP but was wanting to use the PEAKOUT load collector. The Bulk Data on the help says ERP can be used as a result type, but it is not available that I have seen in the GUI. I can change it in the actual code, but if I load the file and change it in Hypermesh the peakout card does not retain the ERP rtype. Has any found a solution to this?
