Hi, I have been attempting to run the network_planning WinProp API example as part of Altair Feko v2025.1. At runtime, I have been getting a "The procedure entry point could not be located in the dynamic link library C:\ProgramFiles\Altair\2025.1\feko\bin\EngineNet.dll" error.
I have added "C:\ProgramFiles\Altair\2025.1\feko\bin" to my Path Environment Variable, and I know that the DLL is being correctly found at runtime. I have also successfully run the outdoor_propgaation API example, which uses the Engine.dll with no issue. I was wondering if anyone has had success running this or another example that uses the EngineNet.dll in v2025.1. I am unsure if this is an issue on my end or if there has been some reported header mismatch with the EngineNet.dll. Any suggestions would be greatly appreciated.
Thanks!
