I am currently using the Create Rough Surface feature in FEKO to generate a surface that represents waves. I would like to understand this feature in more detail.
Is the waveform generated by this function based on a regular mathematical shape such as a sine wave, or does it simply generate a surface randomly? I would appreciate it if you could explain the formula or method used to generate the waveform.
