When applying velocity to parts in MotionView, I want to set the start time and end time for that velocity. Could you tell me how to do that?
Please respond in Japanese or English.
Hello @taichitech, You can create an expression in the Velocity entity properties. Change the Properties Type from "Linear" to "Expressions". Open the "Expressions builder" and create a STEP function. Here are some resources for the same.Creating Motion and changing the properties Instead of an expression you can also give a curve as input to match your user-defined custom velocity inputs.
Hope this helps!
