I have trouble selecting the right thickness parameter when applying copper to my structure :
I understand the thickness parameter is supposed to be the thickness of my structure.
I so have four questions :
1. In the case of a mettalic cube of side 5mm, should i set it to 5mm ?
2. I can read on the tutorial that "It is important to note that the thickness applied to metallic or dielectric faces is not a physical thickness. It is only used to determine the surface impedance."
→ Is it contradictory with my understanding of what this parameter should be ?
3. I wish to makemy structure with a thickness smaller than the skin depth. How am I supposed to process ? I understand the specified thickness here should be greater than two times the skin depth. How to proceed then ?
4. I can read this error message when specifying thickness to the one of my antenna :
Triangle number: 10
Thickness: 5.00000E-04
Lateral dimension: 2.27696E-04
WARNING 2757: A triangle is too thick as compared to the lateral dimensions for application of the skin effect approximation
WARNING 32383: Further warnings 2757 will be suppressed
—> So I guess it means the skin depth computations are not done for these triangles, and that :
"Further warnings 2757 will be suppressed"
—> Does this mean it concerns all my triangles ?
Thanks,
Pierre
