Hello! When I try to import points to create an optimization mask in CADFEKO v2025.1.1, CADFEKO crashes with two error messages the moment I hit "Ok" on the "Import Points" dialog with a file selected; the first error says:
The application has terminated in an unexpected way.
Please contact support with a description of what you were doing together with the following information:
D:\gitlab-runner-root\R-zxhqkcu\0\altairengineering\feko\feko\src\ui\libraries\values\include\values/ClassHierarchyReflection.hxx (23): "pCast": Assertion failed: Can't cast to altair::feko::domainentities::ValueContainer
The second error that pops up immediately after the first says:
cadfeko 9597
00007FFC1CAB6160 (ui_domainentities): (filename not available): altair::feko::domainentities::ValueContainer::getEntity
00007FFBFB965399 (ui_parametrics_gui): (filename not available): altair::feko::parametrics::ParametricExpressionDelegateWrapper::setupValuePointers
00007FFBFB964E0C (ui_parametrics_gui): (filename not available): altair::feko::parametrics::ParametricExpressionDelegateWrapper::paint
00007FFC1C1EF739 (ui_gui): (filename not available): altair::feko::gui::ValueDelegate::paint
00007FFC1E386890 (Qt6Widgets): (filename not available): QTableView::doItemsLayout
00007FFC1E389365 (Qt6Widgets): (filename not available): QTableView::paintEvent
The error boxes, when acknowledged, close CADFEKO.
Here is the contents of mask.txt, which is what I'm trying to import:
0,1
1,1
2,1
3,1
4,1
5,1
6,1
7,1
8,1
9,1
10,1
11,1
12,1
13,1
I'm on Windows 11 25H2, with CADFEKO 2025.1.1-9597.
