I currently have a device that is mounted on a rubber spring. I plan to model it using a bush, but I found that during startup, the device will flatten the bush under its own gravity, which is not in bush with the actual working conditions of the device. How do I set it up and apply a preload to the bush to counteract gravity? Will this affect the performance of the bush?
