Join us this Thursday, November 20, 2025, 7:00 PM - 7:30 PM(UTC+01:00) Brussels, Copenhagen, Madrid, Paris
Agenda
Take your S-CONCRETE usage to the next step. If you are already taking advantage of S-CONCRETE's industry-leading reinforced concrete section design capabilities, you may be looking for ways to improve the workflow between your Structural Analysis results and the concrete section design. The solution is S-CONCRETE's Multistory Designer (MSD). The MSD takes your structural analysis model and result data, and facilitates the concrete design in an efficient workflow, allowing for preliminary section analysis, design group creation, SCO file creation, section refinement, and detailed report generation. Learn more in the upcoming webinar.
Discover how to:
- Prepare your Structural Analysis Model for Concrete Design using the Multistory Designer
- Generate Preliminary Design Results, and prepare section design groups
- Refine section reinforcement based on real-time feedback, comparing your Structural Analysis demands with capacities calculated by S-CONCRETE.
- Prepare detailed Engineering Design reports for your entire concrete structure with the click of a button.
There will also be a live Q+A session.
