I am getting the following error:
job:
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 68566.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 68572.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 68771.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 68774.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 68972.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254768.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254775.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254776.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254780.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254782.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254783.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254786.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254787.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254788.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254793.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254795.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254800.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254801.
*** ERROR 14: Missing property # 2 referenced by CQUAD4 # 254806
there is a property PSOLD #2 associated with the elements in this error, should it be a different type? This is to model connectors as an adhesive joint that references a resin material. What do I need to change?
