I have noticed that when using Compose, the CAE reader (I am usinfg readcae) does not update if the file being read is updated. For example, if I read an "results.h3d" using Compose's readcae created a 8am 11-11-2025, and regenerated the "results.h3d" at 10 am, I would not be able to access the revised results unless I close and open Compose (meaning, there is some Cache the is kept for the 8am version). Is there a command to clear CAE cache without restarting Compose?
Thank you!
