I have a simple problem but i do not know how to solve it.
I have a PEC sphere and equidistant points distributed along phi and theta (501 x 501 points).
At each point I would like to place a magnetic dipoles tangentially to the normal surface, with the same orientation of the theta and phi unit vectors and then load all the excitation from an efe file.
I did this for a PEC plate and it was easy using the APCard, however for the spherical case i do not know how to do it other than manually.
Do you know how can I do this?
