Description:
If you do not specify a ReferenceDensity within a component does it automatically take the density from the Liquid block connected to the circuit or does it remain as the default value in grey (860)?
I have a basic test circuit model; VariableFlowPump (ramped) ResistorTableQp and open tank. I have used a CustomLiquid block for my 50% Water-Glycol mixture, which has a density of 1067 kg/m3 @40°C
When I change the ReferenceDensity value it changes the pressure drop vs flow curve for the component.
Green line = ReferenceDensity = 1067, filled in for components
Blue line = ReferenceDensity = default, not filled in
Thank you in advance :)
P
roduct/Topic Name : Twin Activate 2025 - HydraulicsByFluidon
