I am trying to build a full vehicle model using the msolve api, but could not find any support to add the driver or perform full vehicle events. Please let me know if this is possible
Best Regards Yugal
Hi @16yugal ,
To export the model as a solver deck. In you MotionView session go to File > Export > Solver Deck. Make sure it is set to python and not xml.
I would also go over our free online eLearning to get a better understanding of the interface and vehicle modeling.
https://community.altair.com/home/leaving?allowTrusted=1&target=https%3A%2F%2Flearn.altair.com%2Fenrol%2Findex.php%3Fid%3D496
https://community.altair.com/home/leaving?allowTrusted=1&target=https%3A%2F%2Flearn.altair.com%2Fenrol%2Findex.php%3Fid%3D497
Best,
Christopher Fadanelli
Is it possible, yes. However it might prove to be more challenging. I would suggest generating the full vehicle in MotionView. Then export the model to a python solver deck. There you can edit what is needed instead of building from scratch. There you will also be able to see how the events are called.
Hi Christopher That's great. But how do I export the model to a python solver deck? I wish to create an application that runs full vehicle events that may be used by members in the team less familiar with model setup and MBD. Best Regards Yugal
