I have a report where one column of data is not in the same format as the rest of the data. There are two lines (typically) one for the Invoice total and one for the location total. We pick up location total for our spreadsheets. "Location Total: 00097" (Typical data) then for this one particular state, we have a line that states SPD Total Is there a way to make this a column that I cannot figure out? The "SPD" is another column and you can see that there is a complete separate line for the amount that should be SPD, but I cannot figure out how to add this as a column in Monarch along with the rest of my data. I am using version 11.1...Thanks for any assistance!
___I_N_V_O_I_C_E___ ------ G R O S S ------ --------------- T A X E S --------------- T O T A L CC
Number mmddyyyy EXEMPT TAXABLE STATE COUNTY CITY TRANSIT T A X E S TYPE
SPD
INVOICE TOTAL: 0000000008 02252018 126558.25 123151.23 111315.39 112.43- 76398.31 5.90 310758.40
**LOCATION TOTAL: 00097 126558.25 123151.23 111315.39 112.43- 76398.31 5.90 310758.40
INVOICE TOTAL: 0000000008 02252018 71563.33 330937.20 14297.94 15.10- 67884.23 129.20- 82040.24
SPD TOTALS : Unknown 2.37-
**LOCATION TOTAL: 00098 271563.33 3430937.20 14297.94 15.10- 67884.23 129.20- 82040.24
Are you saying that normally the line after Invoice Total is Location Total, but sometime it could be SPD Totals? What are you using for your detail template? One option would be to make your Invoice Total line the detail template, and create two footer templates, one for Location Total, and the other for SPD total. Be sure to use clearing templates to prevent SPD Totals from being attached to records that do not have that line.
