Is there a way to save or store multiple temp vs pressure curves. Even import or export would be acceptable. I cannot seem to find this capability in 2025.1 and would be stunned to find out if you have to manually enter for each simulation.
Hello @The_Ghost ,
Where are you trying to use Temp vs Pressure Curve? Do you want to export the curve from result section? Can you please elaborate your question a little more in detail?
