does somebpdy know if it is possible to change parameters used in the geometric definition of a machine (e.g. the airgap length or the slot width) in Flux when using the co-simulation in MATLAB/Simulink?
It is pretty easy to do in a solving scenario when just working in Flux. However I wanna use the solution data in MATLAB and was wondering if there was a possibility of just simulating through Simulink from the get-go instead of having to transmit the data via csv files.
There is a section in the documentation for the co-simulation stating that "geometric quantities can appear among the input parameters". I have not found the way to do so, so if you could help that would be great.
Thanks in advance.
