SImsolid: In the Assembly tree if i select multiple parts together and click on "info" tab from dropdown- It does no provide correct mass. Is there a way i can see mass and CG information of a no of parts together from the assembly tree?
Hi Abhishek,
In SimSolid, when you select multiple parts in the assembly tree and use the Info tab, it may not provide the combined mass or center of gravity (CG) correctly because the tool shows properties part by part rather than aggregating them. Currently, SimSolid does not directly display mass and CG for multiple selected components simultaneously in the assembly tree. A common workaround is to create a group or subassembly of the parts you want to evaluate and then check the mass and CG for that group, or alternatively, use the Model Info > Part Mass/Properties panel after temporarily suppressing irrelevant parts to see aggregated values.
Sourav
