Hi @Christopher_Fadanelli
I’ve been exploring the Altair Baja/FSAE library. I wanted to confirm whether there’s an option to add our own or did you provided default already on the chassis? (custom frame geometry) in place of the default one.
If that’s possible, could you please explain the correct procedure or workflow for doing so for example:
- how to import our chassis model into the library environment,
 - whether we need to define attachment points manually(How is that? then), and
 - what file format or setup is recommended.
I’m currently trying to integrate a custom Baja frame and want to ensure I’m following the right process.
Also, i get to know this from the Altair global student team workshop conducted today
Thank you for your time and guidance!
