Hi, I’m performing a steady-state heat transfer analysis in HyperMesh 2024.1.
Currently, I observe a very small temperature gradient in my results, and I suspect it might be a visualization artifact from the software. My assumption is that even if shell structures are perfectly joined, a contact definition is still required. I created a contact using the slide option under the Group section, and I also defined a PCONT card. However, it seems that this setup wasn’t sufficient.
Which steps should I follow to define the thermal contact conductance between surfaces? Could you please help me figure out what I might be missing?
Best
