Hi.
Can someone figure out what is going on with my simulation? I've already tried several things, including changing the transient initialization, but the following error still appears. I've attached my simulation file.
Find attached a copy of your project ready to mesh and to solve.
How did you built initially this project?
using a python script?
Did you make lot of modification in this project, for example delete all the geometry and build a new one to keep the parameters?
I already noticed similar behavior in this case.
I hope this helps.
Best regards.
Cyril Favre
