I am having csv file with sl.no., X, Y, Z, Value data. Totally 5 columns in csv file. While doing pressure mapping by default HM will take only 4th column value as pressure data. but here the 4th column is Z coordinate values.
I need to select 5th column instead of 4th column. Is there any provision available in HyperMesh while doing mapping?
Thanks,
Vignesh
