How to fix the distorted element in 3D tet mesh model. I have meshed a volume with tetra mesh, the elements are shown distorted, which of the element criteria can be edited to fix this problem
you can try this tool
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/meshing/solid_mesh_optimization_t.htm?zoom_highlight=solid+mesh+optimizaiton
or you can try to remedy on the creation
If the issue is on the surface, you may need to update cad or fix surface shell mesh
For big & complicated CAD, never make only one 3D TET mesh. Split your CAD into several sub-domains. Make 3D TET mesh for each sub-domain.
Bu this way you can identify easily where causes the distorted elements.
