I am new to Altair/Hypermesh, I am exploring PhysicsAI. Can anyone tell me if it is possible to import NX structural simulations (.prt,.fem,.sim) and generate Altair format files like h3d or op2 in general to use these in PhysicsAI training
Hi, ArjunSingh_2025,
The h3d and op2 are results file, to be able to generate these files, you will need to run the analysis. If you can use OptiStruct/Radioss (solver), you can run directly in HyperMesh. But, if you´re using another solver, you won´t be able to run it directly in HyperMesh.
BR,
Arthur
Hi @ArjunSingh_2025,
PhysicsAI can read result files from the solvers & formats mentioned in the below help document.
https://help.altair.com/hwdesktop/hwx/topics/reference/extensions/physicsai_faq_import_prepare_data_r.htm
https://help.altair.com/hwdesktop/hwx/topics/panels/upfront_loader_coverage_limitations_hvx_r.htm
We do not see NX simulation result as one of the acceptable format for PhysicsAI.
Many thanks.
Kind Regards
Garima Singh
Engineering Data Science
