After training the romAI model, I created a block to compare the results between romAI and Modelica. After running, my result shows max time = 30, while on the help page it shows max time = 500. How can I adjust the max time?
Hi @Huyen,
You can set the total simulation time from the simulation setup menu. Click on the gear icon on the ribbon toolbar:
You'll be able to define the final simulation time. Hope this helps.
Rafael
