① In Motionview, I used mechanical tools to generate two bearings and solved them in Python format. In Hyperview, I can see the two bearings, but the models of my other objects are not displayed. However, if I submit on the Motionview interface, I can see the models of my other objects. How can I solve this problem?
② I have some pre made Motionview files that need to be sent to others to open. I sent them in MDL format, but the other party only had some Joint files to open. How can I save them so that others can open them perfectly on other computers?
③ Does the extension of mechanical tools in Motionview seem to not support objects within Rigidgroup for the internal and external reference bodies of bearings? I used a bearing and selected an object from the Rigidgroup as the reference body, but the solution would give an error saying that the reference body is not a part. What is the reason for this?
