I am looking to skip an export if it has no rows. I know that you can verify a model to see if it has no rows but the options there are Continue, Stop, Stop without error and in Visual there is one more Continue with verified only. I tried the Visual process using continue with verified only but I guess I didn't set it up right.
I have one large file that has multiple reports inside it so I needed to create 4 models to grab the necessary data, each with its own export. Two of the models are to capture adjustments, which don't always occur daily, so I would like to skip this export if there is no data on these exports and continue with the rest of the process.
Has anyone used verify model and got it to skip the export? I don't want the process to stop as I still have more exports after these 2.
V14.3 Server
