Can I batch generate Washers for a certain face of a solid model in Hypermesh? Another question, I am using the Washer in Quick edit. If I want to generate a Washer smaller than the thickness of the board, then cutting will also be done in the direction of the board thickness (as indicated by the arrow in the picture). Is there any way to avoid it?
