Can EDEM coupled FLUENT export Ensight for post-processing. I now use edem2025 my export interface is as follows, Export Format only Text format
Hi Taijin,
You're correct ensight is not supported for polyhedrals as of today dont know the reason, let me get more details and share little later.
However, can i know why you need to export as ensight format.
Thanks,
Prasad A
I have tried with HyperView (HyperView is an Altair's post processing software) using EDEM and Structural simulations overlaying the two-simulation data but not tried for EDEM and CFD.
You have to load one simulation first and choose overlay option and load second simulation results.
I 'm using polyhedral particles, is that why
I need to show edem particles and fluent fluency in the post-processing. However, edem post-processing does not seem to show the fluent flow field under two-way coupling. I have a report that requires simultaneous display of particles and flow fields. Do you have any solutions,please ?
I ' ll try, thank you
