Hi, All.
I have a steel plates supported by steel frame members. May I ask how to mesh the two objects to make them have shared nodes to work together?
I imported the geometry into Hypermesh as shown below, the red area is the steel plate geometry, the yellow lines are frame members.
When I meshed the area using auto mesh, you can see the meshed shell elements and the frame members are not aligned (black lines and yellow lines are not matched). May I ask how I can mesh the frames and areas to make them working together? Thank you so much.
