Description: Hi there, the issue I'm having is that I've been using the LE-PO solver, but it doesn't work for lossy materials such as aluminum surfaces. I'm specifically trying to obtain a model that accounts for the surface material and surface roughness (200um for example) seen when using a horn-fed dish (single reflector) antenna with 220-240 GHz frequencies. I've been able to do this using PEC, but I've been struggling to figure out how to make a simulation that includes the actual surface material. Thanks!
Product Name : Altair CADFEKO 2023
