Hello!
I've completed beginner hyperstudy learning on the website. I am planing to proceed my first try on aluminium extrusion die bearing optimizations.
But the thing is when press write files on test model tab after i choose the "*.hm" file as resource and "*.hx" file as solver input also hyperextrude as solver execution script. The created "*.grf" file is contains only the (input)variations content, so bearing nodes in this case. There fore solver execute is unable to run while leaving this messsage on the "*.out" file:
load C:/Users/WorkMachine/Desktop/BearingOpt/approaches/setup_1-def/run__00001/m_1/Example.grf phlex {Metal Extrusion}
Error in input data
Bearing Profile data should be after BOUNDAR
Y data
*** INTERNAL ERROR PH89SETBEARINGP
Maximum memory used: 2019 KB
