It looks like you can connect directly to the client thru http://<server address>/RMSClient. From what we have seen, you can connect using the admin id and password only.
So far, we have connected to the datawatch server by going thru the IBM Content Navigator, look for a report and right click and select Mine with RMS. That log you in with the id that you used to connect to ICN. Sometimes when we do not have a report, we want to connect directly but it looks that we can login using only the admin id.
Is there a way to connect to get a user to login directly without using the admin id or going thru ICN.
Thanks...Jim
